Substantial delay when finger playing kick drum or any other percussive Pads in loop. So timing is always off.
Thanks,
David
Thanks,
David
Samples should be played back without delay. Are you using the Sampler to playback the kick drum sample? Which exact djay iOS version are you using?
Version 3.6.6 on my iPad Pro 512 GB, iOS 14.4.1
Of which 393 GB is available.
Yes when I have the sampler open, I’m hitting the pads, and I’d say there
is a half second delay. No was to ever hit it in sync with what is playing.
David
David
David
David
David
