Recognition / indication of compatible keys.
When you ‘sort’ by key DJ Pro (on the ipad at least) shows you in green which keys will mix into the song your playing. Brilliant, by all accounts except when you compare it to the camelot mixing system (http://www.harmonic-mixing.com/howto…), not all of the keys that you could mix into are shown in green so it appears like your choices for harmonic mixing are considerably more limited than they actually would be.
My music theory isn’t that great so there might be a reason for this that I don’t understand but, on the surface it seems like there’s been an oversight in the way this has been put together which (I imagine) should be very easy to fix.
I also think that allowing a choice between the key indication and the camelot (C1 / C2) system for recognising matching keys would be a nice touch.
