Record button?
I am sure it is obvious, but I cannot seem to find it. Where is the record button? I know you can press command “R” but that does not seem to work. Or, if it did work, where do the recordings go? I am using DJpro.
It’s the big red circle at the top center of the screen. Clicking it allows you to create a new recording, and see all previous recordings.
To access your recordings and drag them to other programs, click on Finder. Then go to Roger (or whatever your user name is for your computer). Then to Music, then djay, then Recordings.
Thank you so much! The red button gets hidden when you use four decks. You have to use command r when in that mode. Thank you!
