The duration of the recording is only 1 hour?
Is there any way to expand it? (djay pro windows)
The quality of the sound depends on the DJ console, the program… or what?
I am pretty certain I have recorded for over 2 hrs
I have only recorded once, it took about 1 hour 30 or so and when I stopped it at minute 58 I started putting together the last songs and crowding them together without sense.
What are you using?
iPad, Mac or Windows?
windows. I use windows
No, hablo Italiano e inglese
Hi @pescu, I’ve shared this with the engineering team and they were unable to reproduce this issue on their hardware.
- On Windows, recordings are lossless .wav files, so quality is always set to optimal.
- For the recording to go smoothly you need to make sure your computer has enough free disk space to hold the recording (10 MB per minute). So for a 2 hour mix you need about 1.2GB of free space.
