record set with ddj-200 djay app, tidal
Hi, how can i record my dj set with my ddj-200, djay app, connected with tidal.
i bought audiobus to direct it to garageband. it dont work. i also used audacity and USB Cable to macbook + VB Cable. it dont work.
Does anyone has an idea how to record?
thanks in advance.
Hi @ADFGS here’s an article with some suggestions: How To Record Your DJ Sets (Even When Using Streaming Services)
unfortunately id dont work
I use iPhone, I phone camera kit and Beringher UCA222 audio interface. Works so well. You can then use either GarageBand or Pioneer DJM-REC
Thst sounds good. Can you give me a few more details. I phone what kind of
camera kid? How will I proceed then?
Jason George via Algoriddim Community Forums no-reply@algoriddim.com
schrieb am Sa., 2. Dez. 2023, 20:11:
There you go. This is UK Apple site. Only buy official Apple one as any others won’t work.
