Hello,
Not the biggest problem but might be a bug that would need to be fixed. When playing back a mix I recorded the output is routed directly to channel 3-4 aka headphone but should be to channel 1-2 aka main output. There is a simple work around in just re-routing the main output to channel 3-4 and then it plays just fine, probably a simple coding mishap. Can’t wait for the next update.
Thanks,
Aaron
