I started DJing in clubs in the late 80’s. I played through the 90’s and even stared a bit of the rave scene locally. Mixing has never been an issue and although I’m a firefighter now I’ve found the iPad app to be all I need to do some great work. However, it would be more than helpful if it could be possible to add a mix to the end of an existing mix without having to listen to 38 minutes of mixes first. Is it possible to auto sync the first part of a set without having to let it play while recording?
This is currently not supported but thanks for posting your idea.
Well that was helpful. Glad to see development has worked to make this program better.
