So I’m well aware that you can only record with iTunes library, but once recorded, is there any way of getting that mix online? I have had a few labels contact me and ask for a mix, but I don’t know how to transfer the mix from my DJay app to them? I’m also using the numark IDJpro with the ipad app.
Connect device to your Mac or PC.
Select your device from the Devices section on the left side of iTunes.
Click the Apps tab and scroll down to the bottom of the page.
Under the File Sharing section select djay to retrieve your recordings.
Drag and drop recordings from the Documents list to a folder on your computer.
