Recording Sound Quality isn't 320K, more like 190 k
Anyone having this issue and any suggestions to solve this problem?
Thank you in advance,
TDP
Hi Tory,
Please perform the following:
  • export your recordings to your Mac/PC
  • open the song with iTunes
  • ctrl-click on it and select “Get Info”
What does it say under “Bit Rate”?
which djay version are you using?
Please note that the recording quality can be set to hight bitrates if desired in the settings.
The sound quality for recording a mix is only 128 k. Way too low, should be at least 256 k.
