I’m currently using DJay Pro to record video mixes, but I’m encountering an issue where the output resolution is locked at 1280×720, despite the original video being 1920×1080. I’ve looked through the settings but haven’t found an option to adjust the video recording resolution. Is there a way to configure DJay Pro to record video mixes at 1080p? Any guidance or settings recommendations would be greatly appreciated!
Hi @SimpleSimon, sorry for the delayed reply. I spoke with the engineering team and there is currently no way to configure it. It is automatically selected.
@Slak_Jaw Thanks for getting back to me. I appreciate you checking with the engineering team. Recording at 1080p is a major feature we need for our live video mixes, as 720p doesn’t provide the best quality. It would be great if this could be considered for future updates.
Hi @SimpleSimon, I’ve changed this topic from a question to a suggestion and have forwarded this to the dev team for consideration. In the meantime, please use the blue Vote button at the top left so we can gauge user demand for this. Thanks!
Hi, I’m a user of DJay Pro, and I’m really enjoying the software for recording my video mixes. However, I’ve noticed that the video recording resolution is fixed at 1280x720, which doesn’t match the higher resolution of my original videos, which are 1920x1080. In 2025, with most content being in 1080p or higher, this resolution is no longer sufficient for my needs.
I’ve checked the settings thoroughly, but there’s no option to change the recording resolution to 1080p. I understand that I can use external tools like QuickTime Player to screen record at higher resolutions, but I’m concerned that the quality might not be optimal because DJay Pro might be rendering the video at 1280x720 internally, leading to potential pixelation when scaled up.
It would be fantastic if DJay Pro could offer the flexibility to record video mixes at higher resolutions like 1080p. This would not only improve the quality of my recordings but also make the process more efficient and user-friendly.
I hope the development team can consider adding this feature in a future update. Thank you for your time and consideration.
Hi @SimpleSimon, please do not create multiple topics for same suggestion. This makes it more challenging for us to track and for other users to upvote the suggestion. I’ve merged your new one with your original post. This has already been proposed to the dev team, but I will send them another follow up. Thank you.
