I have a 9th Gen iPad, and I just bought the djay pro for iOS. I hit the record button to record my DJ mix, but there’s no way I know djay is recording, and I can’t find the recording or where it went.
you can find it here
Files/my iPad/djay
I got the folder, but I can’t find the recording
Hi @Rodriguez_II, you can tell that djay is recording your set when the white ring around the djay logo at the top center of the screen turns red (see below). As DJ-Z shared, the set recording can be found using the Files App on your iPad in Locations>On My iPad>djay. The name will start with “Recording” followed by the date and time of the recording. Please also note, that recording using streaming services is not permitted. I hope that helps.
Never mind. I found it; you got to go a different way. My app looks different, so I ‘accidently’ found out how 2 record the mix. Thx!
You’re welcome @Rodriguez_II. Thanks for the follow up.
