When I’ve recorded a set it only plays back through one channel any ideas?
what do you mean it only plays out of one channel?
A recorded set when being played back should play from one channel if its loaded into a deck for playback.
Do mean that you recorded set is playback in mono and not stereo?
Hi guys,
thank you very much for your posts.
@David Dyer What djay version and what devices are you using?
Hi David,
thank you very much for your reply, could you send us a sample of these mono recordings via support@algoriddim.com?
Also could you tell us if you are using external devices besides your iPad ( controller, sound interfaces, splitter cable …).
Thank you very much we will do our best in order to fix this as fast as possible.
Yes mate it only plays back through one speaker
Hi Lukas
I’m using d-jay2 on an i pad
Thanks D
