Reduce hot cue pad size - iOS
YOUR SUGGESTION:
  1. I think they could reduce the size of those scorecard boxes for iPad; they’re too big.
  2. SRT
  3. VDJ
The big difference, those other two programs are laptop software, whereas Djay caters to touch screen interfaces so needs cue points to be large in order to facilitate people being able to quickly touch them.
Hi @MarcosAraujo, thanks for the feedback. @STU-C is correct, the buttons are sized appropriately for touchscreen use. If you use djay on macOS or Windows, the hot cue buttons are smaller. Thanks.
Thank you for your reply.
You’re welcome @MarcosAraujo
A post was merged into an existing topic: Show Hot Cue Names on Waveform
Custom interface for ios. Similar to stand alone alpha theta players.
This will be a game changer . Xdj az , opus quad all have 10 inch screens and if dj pro ai in ios can provide same interface ( playlist , waveform s etc same as Alpha theta display) .will be gr8 for stand alone feel .
Will be very easy for pro djs to switch to dj pro ai.
Thanks for the additional input @DjSasha_DelhiDevils
