Could it be possible to add an option to reduce the space between tracks in the library ?
I would be interesting to be able to see more tracks in the windows instead of scrolling.
Which djay version and which device are you using?
On Mac you can adjust the library columns by dragging them.
I was using it on an iPad pro 12,9 with a Reloop Mixon 4.
Now, I have a MacBook Pro M1 with a Pioneer DDJ 1000.
But I didn’t installed DJAY Pro 2 on it up to now.
I am trying VDJ.
I will try it in a few days.
My remark was not on the column size but on the line’s height
