- DISCLAIMER: i think “related” is a personal preference/taste and should not be confused with the “Matched Tracks” functionality
Hey guys wouldn’t it be nice to have a shortcut to relate 2 tracks while you’re mixing?
Say you’re jamming for the next gig, currently you have the open up the info panel, select the related tab and then drag a track into that tab.
Wouldn’t it be nice to be able to relate two tracks while you’re smiling?
This way you can capture the exiting moment that you realize, this is a kick*ss combo, these tracks belong together.
Where should this function be located?
- Deck menu
- Mixer menu
- Library menu
