release 1.6.4.
I can’t believe it! That’s incredible after all this time! There’s nothing of what we asked from monthes!! Ahhh…let’s go for 1.6.5. and satisfied the request that we made!!
Most of what we added in this update came from user requests and I’m sorry that your personal requests didn’t make it in this update.
Please rest assured that we will continue to consider our loyal supporters’ feedback in each and every update.
Changelog:
:heavy_check_mark: Introducing Audiobus support: Now you can stream live audio directly to other Audiobus-compatible apps! See http://audiob.us for more information
:heavy_check_mark: Added support for Pioneer DDJ-WeGO and DDJ-ERGO controllers (requires Pioneer DJC-WeCAi iPad Connection Cable, sold separately) [nur iPad]
:heavy_check_mark: “Shuffle” setting is now also applied to Automix Queue
:heavy_check_mark: Pause audio when disconnecting headphones or dock audio
:heavy_check_mark: Gain is no longer reset when “Reset EQ” setting is off
:heavy_check_mark: Allow sliding crossfader up after tapping to leave it centered
:heavy_check_mark: Improved handling of iOS audio system errors
:heavy_check_mark: Improved caching
:heavy_check_mark: Improved Vestax Spin 2 mapping: allow tempo fine-adjust using Shift & +/– buttons
:heavy_check_mark: Changed ION iDJ 2 Go jog wheels to scratch during playback (the previous pitch-bend behavior can be enabled using “Jog Pitch Bend Mode” in the MIDI settings)
:heavy_check_mark: Fixed playback issue after loading error with specific files
:heavy_check_mark: Fixed audio distortion when using Key Lock with Bluetooth audio
:heavy_check_mark: Fixed lock screen audio controls starting both turntables
:heavy_check_mark: Fixed possible crash when editing Automix Queue while Automix is active
:heavy_check_mark: Bug fixes, performance and stability improvements
Its actually sad, not a descent update since its release.
AUTOGAIN is a JOKE
Cant read my song titles that have more then two freakin words
Nothing to display previously played songs
SAVE BPM in icloud so when we upgrade our hardware we arent spending weeks anylizing the BPM and THEN manually fixing all the ones your software gets WRONG
PLEASE FOR ONCE RELEASE AN UPDATE THAT HAS SOMETHING WE CAN ACTUALLY BENIFIT FROM AND IMPROVE THE APP’s ORIGINAL & STILL CURRENT ISSUES!!!
Anyone try other iPad DJ software, There aren’t any good DJAY VS _____reviews out there.
I think the update, although has a good selection, would be better if the issues that exist already get tweaked rather than new features added. From what i can see it seems mostly people are asking for a way to change how the song names are displayed and a key lock on-off switch. I would also appreciate it if you could implement these into the ,hopefully not to distant, update.
Exactly - readable song titles (longer than two words…)
Toggle master tempo on/off for all songs from settings
Please fix the stuttering issue when loading new songs that have not been analyzed.
