Hi all,
I’m using djay Pro with Pioneer FLX10 Controller, and I’m having recurring issues with the FX section:
When I press the Release FX button, the LED stays on but the effect is not active – it only activates when the button is off.
Sometimes it works fine, other times it’s completely
off.
Also, the Beat (e.g. 1/2 Echo) and Level/Depth controls don’t match the controller position – even when the knob is at zero, the effect triggers.
Looks like a MIDI sync or pickup issue between the hardware and djay Pro.
I’ve already tried two different mappings, but nothing has improved.
It would be great if anyone could help me out or share a working solution.
Thanks in advance.
- Device model (MacBook M2Pro):
- Version of operating system (e.g. macOS 15):
- Version of djay (5.3):
- Hardware/controllers used (Pioneer FLX10):
