Reloop Beatpad - sampler buttons backlight on djay 2 and Pro
After last “update” another problem. The backlight buttons for sampler is not correct in performance mode on Reloop Beatpad 1. After load any sampler preset from menu is all correct only until first use of buttons. After use backlight will go out. The same behaviour is on djay 2 and djay Pro.
Not solved in new update ! Please return back to appstore Djay 2 for iPad 2.7.x version !!! We all need it now, because Christmas parties !
thank you very much for your post!
Could you please contact us via support@algoriddim.com and tell us which iOS and device you are using right now.
That would be great, we will do our best in order to help you out as fast as possible.
Keep it up!
