So when using djay with a Numark iDJ Pro the UI changes to a specific portrait format.
Are there any plans to do the same for the Reloop Beatpad, eg. remove the no longer required touch controls that are on the controller - channel/pitch/cross faders and transport controls - and use the extra space this provides for larger FX and/or sampler controls, loop size info, etc? The Beatpad lacks a dedicated dry/wet control so a large prominent on screen slide control may work well, perhaps down the sides where the pitch faders are currently located…only much bigger.
