- Device model: iPad Pro 12.9” 3rd gen
- Version of operating system: IPadOS 26.4.2
- Version of djay: 5.6.5 Pro
- Hardware/controllers used: Reloop Buddy
- Hardware firmware version: N/A
selecting the performance mode: “sampler” and “looper” (double press to change the window also in djay pro on Ipad) it shows always the sampler window and to select the looper I need to tap on the Ipad the icon of the looper
press “mode” key
double press “looper" pad
C) EXPECTED RESULTS:
looper section displayed in djay pro
D) ACTUAL RESULTS:
sampler section displayed in djay pro
Hi @Borgata_Zimmerwald, welcome to the Community! Thanks for the details about your setup and the issue. This is very helpful.
- Are you using the (built-in) MIDI mapping for the Buddy or a custom edit?
- When you double-tap the Looper Pad mode, do the pads on the hardware control the Looper even though the UI doesn’t change to the Looper? Or are the hardware pads controlling the Sampler?
- Did this work as expected on a previous version of djay before 5.6.5?
- Do you have a macOS or Windows device running djay? If so, does the same issue occur on those platforms?
- What does a single-tap of the Looper Pad mode do? Is it the same result as the double-tap?
- Does this issue happen 100% of the time or is it intermittent?
- Do you experience this issue with other Pad Modes or only the Looper?
- Can you please capture and share a short video of the issue?
Thanks for answering my questions @Borgata_Zimmerwald. I have passed this onto our hardware engineering team to see if they can reproduce the issue on their setup and offer any suggestions. I’ll report back when I have more news. Thanks!
