Same thing happening to me but on a Reloop Buddy controller.
Hi @Felipe_Fenton, Thanks for reporting this issue with cue point drift when using the Reloop Buddy. As the bug reported on the other thread you posted on has since been resolved with the release of djay version 4.0.7, I’ve moved your post to this new thread so we can better look into the current issue you’re experiencing.
So we can take a closer look, could you please tell us the following:
- What device are you currently using?
- Which OS version is running on your device?
- Which djay version are you using? (If you are using an iOS/ Android device, please open the djay settings and scroll down to determine the version number.)
- Please explain step-by-step the issue you are experiencing, what you expect to happen, and what actually happens.
Thanks in advance for the additional information!
