Hi algoriddim team,
I have small but very useful wish. Is it possible to switch to looper menu when I double tap to “looper” performance button? At the moment it switches to “sampler” menu. It will improve a lot the workflow. Thank you
best
Sergei
Hi algoriddim team,
best
Sergei
You could always try to midi map that function for you.
I was going to suggest the exact same suggestion that you have posted. It probably will be the easiest fix for now
Thank you guys.
As quick fix it works, but it still requires at least 2 actions (go to sampler menu + switch to looper menu) which is not user friendly.
