Good morning. I am the owner of the reloop Buddy . Until 4 weeks ago it was still possible. Could play music with the DJ pult via pc. Now, however, there is no more transmission. The DJ booth is not integrated into the app anyway. I don’t know what to do anymore. Can someone help me with that. possibly a setting. Have Win. 10 .
@Avelances make sure you are connected to the USB-B socket with a high quality USB cable and the switch on the side is set to PC not iOS.
I did that. The mudi is found on my daughter’s laptop. My PC constantly says, no MIDI devices found. The app works on the PC but unfortunately the reloop buddy doesn’t work. The laptop where possible is not powerful enough for the hardware. could it be the Windows version?
- Have you installed the Windows ASIO driver from the Reloop website?
Reloop Buddy - Reloop - What version of Windows are you using?
- What version of djay Pro are you using?
- Do you have a paid subscription for djay Pro?
Hi @Avelances, did you get my last response? Are you still having connection issues?
