Just got a small power bank for back up. It’s 5v output (9000000mAh - whatever that means) and seems to work ok with most things. Direct into iPad: Yes. Via USB hub: No. Mini rig speaker: Yes
However it definitely doesn’t work to power up Buddy controller (they say 5v, so I’d assume it should).
I’m wondering if this is common, before I make assumption its just this power bank and invest in another.
PS: Also read somewhere on Reddit that reloop doesn’t have good sound quality master outputs. I haven’t tried it on any other systems other than at home, so not noticed any issue so far, but its this a thing?
In addition to the Voltage, you need to consider the Amperage requirements of the Buddy. This info should be available in the user manual. Then make sure your power bank can meet or exceed the Amperage requirements as well.
Yes, that’s exactly the info you need. 5V, 2A. 2A is 2 Amps. This equates to a 10 Watt power supply requirement. Your power bank needs to supply at least these values.
