reloop elite effects real vinyl
Hey,
i consider using the reloop elite with algoriddim djay pro on my ipad. with serato the mixer has the ability to use the serato effects also on real vinyl records. does this also work with algoriddims effects?
Hi @Ricekopf,
Thank you for your post! This is a great question and I will check in with our development team to give you a correct answer!
I’ll keep you updated the moment I receive any word!
Yes you can do it. Set both turntables to whatever DVS channel you have selected either A/B. Once you boot up Algoriddim and The Elite just switch either channel or both to your phono line. The FX will be accessible just turn them on as you wish. Easy.
Thanks for sharing @Dj_V
