Reloop Elite mixer
Hey. I’m considering purchasing a Reloop Elite mixer. I spin vinyl predominantly and want to know if the reloop elite sound quality is good for vinyl and if i can use the effects without being connected to a laptop.
Your question:
Hi @RikDucci,
Thanks for sharing your question!
The Reloop Elite is supported in djay Pro for Mac as well as iOS as shown on our DVS page at the link below.
Additionally, could you speak more about using FX without being connected to a laptop?
I just would like to use its onboard effects without having to connect to a laptop
Hi @RikDucci, this is probably more of a question for the Reloop support team, but reading through the Reloop Elite user manual, it appears that it has built-in hardware effects, known as “Tweak FX”, which can be applied directly to the mixer channels without the need for a connected computer. I hope that helps!
