That’s great news @Polyura. Thanks for the follow up. It sounds like Protect Active Deck is working as expected based on your description. I would simply turn the off in the djay Settings>General>SONG LOADING.
I found a glitch in the Neural EQ! When I switch to the standard equalizer, nothing changes, and when I switch back to Neq mode, the program starts cutting vocals from + frequencies (only restarting the program helps to go back!
Any idea? How to fix this?
Hi @Polyura, please try MIDI mapping a free button on your ELITE to Toggle Neural Mix - EQ instead of changing this via the iPad.
Hi @Polyura, can you please share screenshots of your mapping for the EQ knobs and the NM/EQ toggle button? It’s difficult to read this in your video. Thanks!
Thanks @Polyura, please also share a screenshot of your mapping for the EQ and NM EQ knobs.
Yes, that is for the toggle button. I also need to see how your EQ knobs and Neural Mix EQ knobs are mapped. See examples below:
Thanks @Polyura. I suspect this is your problem. Try mapping your EQ knobs to back regular “High EQ”, “Mid EQ” and “Low EQ” instead of to NM EQs. The “Toggle Neural Mix EQ” button that you mapped earlier should take care of switching between to two modes.
Hello!!! Thank you very much!!! Everything worked as you said!!!
Perfect! You’re welcome @Polyura
