Reloop Flux, DVS signal too high
Hello everyone, just bought a Flux for DVS like everyone suggested. But why the signal on my mixer is too high and strong ?
Hi @Thejazzlounge, please note that the Reloop Flux is currently not natively supported with djay. Please contact Reloop support regarding this device to see if they can suggest some hardware adjustments for you. Thanks!
I was suggested to buy the flux for this, so my question is WHICH IS SUPPORTED PLEASE . As it seems that the software isn’t compatible with any audio interface
Hi again @Thejazzlounge, to reduce the output signal from the Flux to your mixer, please try increasing the Output Headroom in the djay Settings>Sound.
