Reloop Flux Go + Mixtour = DVS mode with djay!
Just to share my DVS setup thx to Reloop Flux Go and Djay !
I can now use the Mixtour in DVS mode :heart_eyes:
Tony.
One thing from me, dont forget to disable bluetooth on your tablet as it avoids letency issues. I had this problem with the original Flux.
Ok, thx for this information.
For the moment, no issues with the Go version.
Nice! Thanks for sharing @DJTonyBlanck
and another one… :grin: :grin: :grin:
I really like this set up :heart_eyes:
I’d love to use a setup like this as it just looks so right! But one question, how does it work if you need to use headphones?
@BillPayer, I’m pretty sure you would connect your headphones to the the Mixtour Pro - not the Flux Go.
Yes! DVS configuration with Flux Go, master and headphones with Mixtour Pro, so I can Have post fader FX :heart_eyes:
Thanks for confirming @DJTonyBlanck
Even in an iPad? I thought you could only specify one audio device on iPad OS?
If you can do this on an iPad and Mac, this is a dream setup.
Nope, you can specify two… :wink:
I tried it on MAC, I have a latency as soon as I declare the second one. I will investigate if I have time.
FLUX (not go the first) and djay on ipad , also with bt off, a lot of latency…
I don’t experience that with the Flux GO… lucky me :grin:
Official support for the Flux Go on macOS and Windows has been added in the djay 5.6.3 release.
What about the OG Slak? can we expect that to come anytime soon :slight_smile:
That was also added with 5.6.3
  • Support for Reloop Flux and Flux GO DVS audio interfaces (macOS, Windows)
A post was merged into an existing topic: Reloop Flux Interface
