Looking for some guidance, for cables and mapping. Help me out if you can please.
Gruvone in Denver
Hi J Garcia,
regarding the mapping, the Mixon 4 is natively supported by djay Pro for the iPad.
Cheers,Lukas E.
Hey there,
the Reloop Mixage is not supported. you can see all supported controllers via:
https://www.algoriddim.com/hardware
Cheers,Lukas E.
Como puedo saber si el controlador reloop mixage EI funciona con djay pro
