Cannot connect to iPad Pro no matter what usb c cable I try., and yes firmware is updated and
ISO switch is on. Any help would be appreciated thank you
@angel.ortiz2 make sure you have your input sources for each channel switched to USB-A.
Thank you the information helped me out your great!
@angel.ortiz2 you’re welcome! Glad that worked for you.
Thank you it work your awesome!!
Hey @angel.ortiz2 - Welcome to the Community! Thanks for your post.
It looks like @Slak_Jaw pointed you in the right direction! Thanks for that
Feel free to continue interacting here in the Community if anything else comes up for you or should you have any ideas or suggestions!
