I’m having issues on songs I loaded in channels with the gain knobs. When I load them they are low and when I try to increase volume they shoot up very loud. Is there anything I can try to prevent this?
Hi @Jesse_Ramos
Thank you for getting in touch and welcome to our community. Do you have Auto Gain activated in the djay Mixer settings? If you want to manually setup your Gain levels I would suggest disabling the setting.
Dammit Lukas! Your a life saver! It worked
