Hi @DJ_Faisal, it sounds like you’ve tried most of the things I would normally suggest. One more thing you could try is to connect using one of the other USB sockets on the back of the Mixon 8. Just be sure to change your inputs to match with the small switches near the Gain Knobs for each deck. If this doesn’t work, then I would contact Reloop support as this sounds to me like a hardware issue.
I have contacted reloop. Thank you for your suggestions. If you all have any recommendations for other controllers, I would appreciate it.
Hi there, hope your Mixon 8 gets fixed. I had a Mixon 8 and had issues. In the end I changed for pioneer Rev 5. In a lot of respects it’s mapped better for djay pro. I like it a lot.
You’re welcome @DJ_Faisal. Please report back on how things go with Reloop support.
That’s exactly what I’ve been looking into Rev 5 reviews. However, I could not find any reviews of how Rev 5 and DJAY work together. Hopefully it is mapped correctly. I need something that is reliable. I used to have DDJ800 and NS62 and both were very reliable.
Thanks for your input.
Yes, absolutely. They responded quickly.
M8 is working fine now. I turned on the next day and everything was working fine.
Weird. Glad to hear it’s working. Thanks for the follow up.
I moved on to FLX-10 got got a good deal on it. It works great with djay and other softwares. No display on jog wheels though with djay, and no i pad slot. So far, plug and play with Djay, but I need to learn more about it. Definitely like better than M8.
