Reloop Mixon 8 pro case
Hello, I could not find dj workstation for reloop Mixon 8 pro:
Any suggestions
Other brands are usually too heavy
Check out Magma and Odyssey cases. Also note that the Mixon 4 is the same size so those cases should fit the 8 as well.
Ok then I will just Mixon 4 case
@DJ_Faisal The Mixon 4 Decksaver also fits the Mixon 8. I ended up going with a Decksaver and the Magma XXL Plus II EVA soft case.
I do have the odyssey soft case. Flight cases are heavy.
Yeah, I’m not a flight case fan. They are way too heavy IMO. I put my Mixon 8 with Decksaver and soft case inside an XL suitcase when I travel.
Agree, the only thing I like the gliding table. I might just add a laptop stand.
You may want to check this:
https://www.strumentimusicali.net/product_info.php/products_id/76156/udg-creator-pioneer-ddj-flx10-reloop-mixon-8-pro-hardcase-black-u8305bl.html
I have similar Odyssey brand.Ty.
