Hi!
I just purchased the Reloop Mixtour.
I would like to know whether to Djay Pro on Mac Pro i can map the library wheel so that it can also act as jog seek on deck… Thank you!!
Yes sure. I open the midi configuration and I can set the new commands.
For example, I could use the combination of the Fx button on deck and library wheel ? Thanks
Yes its possible … Do you know how the mapping function works?
