I switched from Traktor Pro to Algoriddim djay because I needed to use Phase in wireless (HID) mode and have a mixer/controller with built-in pads and an effects section (all-in-one), making it easy to transport and set up.
My current setup is:
• Reloop Mixtour Pro (latest firmware update)
• Phase DJ Essential (latest firmware update)
• Reloop RP7000 MKII
• Algoriddim djay Pro 5.2.9
• MacBook Air i5, 8GB RAM (updated to macOS 12.7.6)
The two main issues, which did not occur with other softwares and platforms using a same setup, are:
BPM fluctuations during playback with Phase in HID mode. When I recalibrate Phase (on spot), the BPM usually returns to normal, but with djay Pro, this does not work.
Noise/distortion when releasing the record after scratching or mixing. When I release the record after a mix or a scratch, the software produces an unusual sound before stabilizing playback. This did not happen with other softwares using the same setup.
