Reloop Mixtour Pro Firmware update 1.0.1 > 1.0.2.
  • Device model: iPhone 12 Pro
  • Version of operating system: iOS 18.3
  • Version of djay: 5.2.10
  • Hardware/controllers used: Reloop Mixtour Pro
I bought a Mixtour Pro and connected an iPhone 12 Pro to it. After downloading Djay Pro 5.2.10, a firmware update message popped up. It says to upgrade to version 1.0.1. But it also says that I have version 1.0.2 installed.
I checked the Reloop website, and the firmware version there is also 1.0.1.
Has anyone else run into this? Do I need to update the firmware because version 1.0.2 is older than 1.0.1?
I reached out to Reloop support, but they haven’t responded yet.
Hi @Zirrex, good catch! I just checked with my Mixtour Pro and am getting the same message. I also checked the Reloop downloads and it’s showing v1.01 as well. Let me check with the engineering team here and see if they can shed some light on this. I’ll let you know as soon as I hear back.
Hi again @Zirrex, we are indeed providing firmware 1.0.2 inside the latest djay release. The version numbers in that message were unfortunately swapped. We will correct this wording in the next release to avoid the confusion. Reloop also has not yet added version 1.0.2 to their website. Sorry again for the confusion and thanks for pointing out the mistake!
