Reloop Mixtour Pro Knobs/Pitch Bug Report
  • Device model: Ryzen7 / 16GB / 500GB
  • Version of operating system: Windows 11
  • Version of djay: 5.3.3
  • Hardware/controllers used: Reloop Mixtour Pro (Latest firmware as of 25-06-16)
I have owned Reloop Mixtour Pro for almost a year now and though that I love the device, it still is a bit rough on the edges (atleast on Windows). Even if there is no major problems, there is still some things I hope Algoriddims can fix.
EQ / Filter knobs not tweaked for Djay Pro
When I put the EQ on the 9 o clock position, the software think they are completely off;
The Crossfader has similar issues:
Pitch doesn’t alter bpm by minor one value (0.1) but by minor three value (0.3). Or by 0.2%
Skärmbild 2025-06-16 090836
Minor problems perhaps, but still annoying.
Thanks in advance!
Hi @djfredhaze, thanks for the details and screenshots related to your issues.
  1. The BPM precision is a known issue that our team is already investigating.
  2. I was not able to replicate your EQ and Crossfader issues on my Windows setup with the Mixtour Pro. Can you please confirm if you are using the (built-in) MIDI mapping or a custom edit.
  3. Can you please open the MIDI Learn tool in djay, turn the High EQ knob, expand the Advanced Control Options section, and share a screenshot of this?
  4. Please do the same for your Crossfader.
I’ll save you the screenshot for the built in Configuration, it looks the same
Thanks @djfredhaze, interesting. Do you have another device like an iPhone or iPad that you could test the Mixtour Pro with? This seems like it could be a hardware issue. I tested my Mixtour Pro with the latest firmware on Windows, iPhone, iPad and MacBook and it behaves as expected.
Must be a hardware issue then, as you said.
Going to re-install Djay Pro and do a bit of testing.
I’ll report back here if I find anything. Otherwise I see this case closed.
Thanks for your time Slak_Jaw!
You’re welcome @djfredhaze. Happy to help!
Update: Figured out the problem.
When I start Djay Pro the audio device automatically choose WASAPI (If not told otherwise) and the weird Insync with the buttons happens.
When I change to ASIO, all buttons works fine.
So if this problem or similar problems happens, always check if ASIO is chosen and not WASAPI.
Ah yeah, I sometimes forget that Windows has the audio driver configurations. Glad you figured it out @djfredhaze. Thanks for sharing!
