there are two situations with the application. 1. When the phone is not connected to the controller, there are no periodic clicks, and they appear only when switching settings. 2. When the phone is connected to the controller, there are periodic clicks during playback and when switching settings.
Thanks for the videos and additional info @_360
Hi @_360, our engineering was able to reproduce this and they’re investigating further. I’ll share more news when I have it.
Hi, and thank you, I’m really looking forward to the decision. I am following this discussion.
You’re welcome
Hi again @_360, are you running Android OS 15? If so, can you please try updating to Android 16 and retesting with the Mixtour Pro? Thanks!
hello. yes, I have Android 15 and Hyper OS 2 installed. but so far I can’t upgrade to Hyper OS 3 and Android 16, the update can’t be installed on my phone.
I have checked the Djay version 5.3.3 and there is no interference when switching settings on the “sound” tab. however, arbitrary clicks are also present during playback.
Thanks for confirming @_360. Are you able to downgrade to Android 14?
I don’t have that option either.
Okay. We are pretty sure this issue is mostly isolated to Android 15.
I tested DJAY on a Samsung S25+ phone with Android 16, the result is the same.
Okay, thanks for the additional info @_360
Same problem on Android 15 xiaomi mi12t pro
On Xiaomi Mi pad 5 Android 14 djay just crashing when you press mode button
Thanks for sharing @Rush52nn. Our team is aware of this. Are you able to update to Android 16 and retest?
Android 16 have other problems
Understood. Thanks for linking to your other topic.
