Reloop Mixtour Pro with Turntables
Is there anyway possible to use the Mixtour Pro as a mixer to work with vinyl turntables thanks
The use of turntables should be possible with Phase DJ in HID mode. Direct use of vinyl records is not possible with the Mixtour Pro.
Thanks @Chris_R. You’re correct. You’d need to use Phase as the Mixtour Pro is not directly DVS or turntable compatible - it has no inputs for external devices.
the only compact solution is akai amx, that is able to read dvs, and could run with djay :slight_smile:
Thanks for sharing @carletto_dj. However, please note that this hardware currently is not officially supported in djay and some users have reported mixed results.
is HID Mode in phase available in iOS on ipad pro m5 ios 26? if so how can i activate
Hi @djessa, Phase HID mode is currently only available on desktop (macOS/Windows).
