- Hardware firmware version (e.g. 1.0.1):
- Please consider sharing a short video or screenshots to help clarify your question/suggestion/feedback
- Reloop Mixtour Pro works with Samsung s24 and current, no 4 deck mixing only 2 for Android, Apple Ipad 9th generation ( via lightning connector, Amazon..com or Walmart, dependingon your location, example USA, Canada, Europe, Asia, etc ) all current Apple Ipad models, and yes you can do 4 deck mixing not hard to do just pay attention to the deck selection and prior to bringing in the mix make sure to keep volume level down, neural stem adjustment. Also please make sure to invest in a solid portable charger, and high end usb cables, though the unit comes with one I do recommend Anker cables. And a decksaver, and the Reloop Mixtour Pro tour bag. Party On and it is all about the music:speaker_high_volume:
Thank You Laidback Luke
