5.3.1 with MacOS
Denon MC4000
Reloop Neon
Hi
I recently mapped the basic functions of Neural Mix to the Slicer on the Reloop Neon.
I have never done this before in Algoriddim DJ.
I mapped the 4 channels Drums, Harmony etc to the top row and Mute to the second row of the 8 pads.
The problem I am having is no lights. The pads do not light up. Is this normal or have I missed something in mapping?
Hi @Iddison68 LED output for each MIDI command is controlled is controlled using the MIDI Out section. Ensure this is enabled for each MIDI command. The Min Value controls the LED color when the button is not pressed. The Max Value controls the LED color when the button is pressed. These values are different for every controller so you will need to experiment. Also note that some values will have the same LED color but with different brightness. I hope that helps!
Thanks for that, I will give it a go now.
You’re welcome @Iddison68
