I can’t get any sound out of my controller. I’ve tried everything! Ever since the update sound does not come out of my controller for pre-cueing. Also, how do you change the LED lights??? Why doesn’t Algoriddim just add support for the Terminal Mix 8?? Support for the 2, and the 4, but not 8?? Come on!
This reply was created from a merged topic originally titled Still no sound out of my Terminal Mix 8 by Reloop. Also, can someone make a video….
I had previously made a post of this problem since the update of 1.1 no sound comes out of my controller. I know it’s a software problem. What’s the scoop Warren?
First off, rest assured, we’ll keep on supporting new controllers.
However, your Reloop Terminal Mix 8 should be working with djay Pro. Please make sure you’re using the latest update. Now, have a look at the “Device” preferences: the Reloop Terminal Mix 8 must be selected for both, your Main- and Pre-Cueing Output.
Lastly, I’m sorry, your LEDs can’t be mapped.
midi learn does not map properly decks 3&4 for FX, it is stuck on using fx from 1&2
