Remapping 'deck select' issue Denon LC6000 / iOS
I was very excited when I discovered the Denon LC6000 as a single-deck solution to controlling four decks on the iOS version of Djay Pro. HOWEVER! The in-built deck select system on the LC6000 is fiddly—it requires using the shift button, and the deck buttons are not in the intuitive order (i.e., matching the deck order on the screen).
… I thought, ‘no problem, I’ll just remap the deck select function’… however, this doesn’t seem to work - it doesn’t seem possible to control any function in the ‘General’ section of MIDI controls from the LC6000 - can this be true? Is it possible to get around?
Any thoughts gratefully received!
  • Device model iPad Pro
  • Version of operating system 17.6.1
  • Version of djay 5.2.3
  • Hardware/controllers used Denon LC6000
Hi @Jake_Williams, sorry for the delayed response. Deck selection on the LC6000 is handled inside the device, so unfortunately it cannot be remapped. This is a technical limitation of the hardware. Thanks!
