Remember master Sampler volume
Every time I close the app and reopen it always sets the volume back to max no matter where I left it.
Hi @Reign712, thanks for the suggestion. I will pass this onto the dev team for consideration. Out of curiosity, are you using a DJ controller with a dedicated Sample Volume knob or fader? Or are you using djay without a controller? Thanks!
I have found that if you edit the volume of individual samples, it does remember these settings. To me this is more important.
Thanks for sharing @Midas
Yes, the master volume default forced me to set the volume for each sample individually which could be up to 32 samples across banks so yes it’s a workaround but would be much easier to not need to have to do this at all working all values back from that max volume setting, should be reasonably easy for an engineering team to implement.
Thanks for the additional input @Reign712
Agreed! While we’re at it, it would be good be able to add effects to the samples too! LOL!
Hi @Midas, there’s an existing suggestion for this: Sampler & Looper / FX and cue
What a dream! I manually added the FX and recorded those into my banks…so some are wet and some dry…another work around lol.
Sorry @Slak_Jaw just seeing the question part and I use a controller with a dedicated sampler volume knob (which is super handy too in case I forget) and one that doesn’t have a knob…so all flavors basically.
Thanks for confirming @Reign712.
