Does the “dJay Remote” app, have Pre Cueing feature? As in can I listen to the Pre-cued song on my mac in my iPhone using the remote app? I don’t have the splitter cable, and it isn’t easily available in India, but if this feature is available via remote app then that solves it for me…
Thanks for contacting us.
Pre-cueing is not supported with the djay Remote app.
By the way, you don’t necessarily need the split cable for pre-cueing. Generally speaking, you can also use any external USB sound card supported by the system with djay for Mac.
