Hello,
is there a way to remove the “scratch” sound when I stop a song that is playing?
Thank you
Alex
Hello,
Thank you
Alex
Hi Alex,
could you check if you set a Stop Time in the djay Pro settings?
You can find them by going to the Settings ( cmd + , ), now click General and you can find the Stop Time under Deck.
Hope this is helping.
I just downloaded the new version for iOS and I also am looking for a way to remove the scrubbing sound when a track is halted. I need to be abel to cue a LIVE tune (start and stop) without the scrubbing sound.
