Removing a song from a turntable
Hi all! Just installed Djay2 for iPad. Works great but my french brain can’t get how to remove a song once it’s loaded on a turntable. Looked at the FAQ, but couldnt figure out how to do. Any hint (other than getting a real brain? ;op). Thx
Great advice.
but how do you go about it on djay pro 2 for Mac?
Press and hold the icon that loads songs to that deck, a secondary button will pop up that says unload / or another button with the option to load the same song on both turn tables
Thanks!!!
