When I go to remove all songs from the queue…there is still 13 songs that are supposedly still in the key. Where are they, and how can I remove them? Any help would be great.
could you tell us in more detail what problem you are facing? Are there 13 tracks remaining in the Queue after you tried to remove all songs?
Thank you in advance.
I figured it out. Thanks for the quick response though!! I figured out how to bring the key up in the bottom window and removed them from there.
