I’ve got a playlist with songs from my personal library and Spotify and when I select a track from Spotify within that playlist and select “Remove from Playlist” it will remove a different song from the playlist and not the one I selected.
Hi Connor,
I am very sorry to hear that.
Can you tell me which exact djay version you are using and in which playlist you are removing a song?
Hi Connor,
it would also be helpful if you can send us an exemplary video in which you are pointing out the problem you have to deal with.
You can send us the video per mail via support@algoriddim.com.
